help with contact analysis project
Tinu30
Student
GB
hi All,
I'm doing a project analyzing the contact pressure/stresses of the soft tissues of lower residual limb. I've created parts for the limb, liner. The parts for the prosthesis socket and femur bone were provided by my project supervisor.
A Boolean cut operation was used to cut the femur part from the limb part leaving a hole representing the femur surface
the limb/femur are modeled as one body with different property types assigned. there is an overlap in section assignment of the femur set and the limb set. I don't know if this affects analysis
The limb is modeled with 3nd order Ogden hyper-elasticity property. Femur, liner and socket all have linear elastic properties
all have been meshed with linear tetrahedral elements. the limb used hybrid linear tetrahedral elements. only 5 elements are distorted after checking for mesh validity
Contact formulation created for contact between liner and limb and liner and socket. friction coefficient used is 0.5. Tangential behaviour set to penalty. Normal behaviour set to hard contact for pressure-overclosure. adjusmtent set to remove overclosures
nodes of the femur surface are coupled to a reference point (RP) below socket representing the knee joint.
3 different load cases of forces/moments individually are applied to this RP to simulate different phases of walking - foot flat, midstance, heel of
outer surface of the socket is has fixed (encastre) BCs
I'm having trouble running the analysis. I get various warning messages anywhere from negative eigenvalues, zero force, zero moments, zero vol. flux etc
step definition
intial = 1E-05, min = 1E-50, max = 0.05, number of increments 1000
I've changed number of interations attempts from 8 to 50.
Right now I am running the analysis with RP fixed in all degrees of freedom except U2 and UR1
the load/moments applied at RP is;
CF1 = 133 CM1 = 20
CF2 = -923 CM2 = -4
CF3 = 60 CM3 = -22
here's an example of the warning messages I am getting. this is from increment 1, attempt 13:
WARNING: THE SYSTEM MATRIX HAS 548 NEGATIVE EIGENVALUES.
EXPLANATIONS ARE SUGGESTED AFTER THE FIRST OCCURRENCE OF THIS MESSAGE.
CONTACT PAIR (ASSEMBLY_RESIDUUM-BONE CUTOUT-1_LIMB_EXTERNAL,ASSEMBLY_NEW
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4429 OPENS BY
2.33046E-15 WITH A CONTACT PRESSURE/FORCE OF -6.71433E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.460 IS OVERCLOSED BY
12.7939E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3071 IS OVERCLOSED BY
5.77684E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3084 IS OVERCLOSED BY
5.09783E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3097 IS OVERCLOSED BY
5.91762E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4436 OPENS BY
-3.80067E-15 WITH A CONTACT PRESSURE/FORCE OF -547.852E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4420 IS OVERCLOSED BY
3.19565E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4451 IS OVERCLOSED BY
14.7245E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3045 IS OVERCLOSED BY
12.9527E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4412 IS OVERCLOSED BY
2.65430E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3099 IS OVERCLOSED BY
6.22275E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3086 OPENS BY
-6.41981E-15 WITH A CONTACT PRESSURE/FORCE OF -4.62968E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3073 IS OVERCLOSED BY
1.19179E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3112 IS OVERCLOSED BY
6.10088E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3125 OPENS BY
-9.79780E-15 WITH A CONTACT PRESSURE/FORCE OF -6.41978E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3123 IS OVERCLOSED BY
2.92113E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4442 IS OVERCLOSED BY
16.2386E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4458 OPENS BY
-17.2226E-15 WITH A CONTACT PRESSURE/FORCE OF -349.144E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4426 IS OVERCLOSED BY
14.9425E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3032 IS OVERCLOSED BY
12.2716E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4397 OPENS BY
3.00784E-15 WITH A CONTACT PRESSURE/FORCE OF -17.8557E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4411 IS OVERCLOSED BY
9.21575E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3060 OPENS BY
7.80648E-15 WITH A CONTACT PRESSURE/FORCE OF -5.24939E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3136 IS OVERCLOSED BY
299.481E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4449 IS OVERCLOSED BY
20.0132E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4466 IS OVERCLOSED BY
19.7997E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4425 IS OVERCLOSED BY
15.5637E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4470 IS OVERCLOSED BY
8.42550E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3019 IS OVERCLOSED BY
5.66560E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4403 IS OVERCLOSED BY
9.28678E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4464 IS OVERCLOSED BY
12.2417E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4473 IS OVERCLOSED BY
22.1920E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4475 IS OVERCLOSED BY
13.0530E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4476 IS OVERCLOSED BY
7.27395E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4478 IS OVERCLOSED BY
2.84382E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3006 OPENS BY
9.99284E-15 WITH A CONTACT PRESSURE/FORCE OF -6.23689E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3034 OPENS BY
-524.871E-18 WITH A CONTACT PRESSURE/FORCE OF -6.48439E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4381 OPENS BY
2.39756E-15 WITH A CONTACT PRESSURE/FORCE OF -666.856E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4388 OPENS BY
-1.10622E-15 WITH A CONTACT PRESSURE/FORCE OF -214.049E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3102 IS OVERCLOSED BY
1.48908E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3089 IS OVERCLOSED BY
4.62639E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3162 IS OVERCLOSED BY
1.56243E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4481 IS OVERCLOSED BY
18.6282E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4482 OPENS BY
-22.3186E-15 WITH A CONTACT PRESSURE/FORCE OF -952.736E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4484 OPENS BY
-7.05856E-15 WITH A CONTACT PRESSURE/FORCE OF -2.38294E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2993 OPENS BY
6.39018E-15 WITH A CONTACT PRESSURE/FORCE OF -16.5484E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3021 OPENS BY
-8.12471E-15 WITH A CONTACT PRESSURE/FORCE OF -3.81763E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4387 OPENS BY
-4.51053E-15 WITH A CONTACT PRESSURE/FORCE OF -625.595E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4401 IS OVERCLOSED BY
10.9008E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3142 OPENS BY
-2.23801E-15 WITH A CONTACT PRESSURE/FORCE OF -12.4766E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3168 OPENS BY
3.17404E-15 WITH A CONTACT PRESSURE/FORCE OF -17.9957E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3179 OPENS BY
4.07867E-15 WITH A CONTACT PRESSURE/FORCE OF -4.29612E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3175 IS OVERCLOSED BY
4.80578E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4490 OPENS BY
-19.4730E-15 WITH A CONTACT PRESSURE/FORCE OF -1.63713E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4491 IS OVERCLOSED BY
16.9413E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4493 IS OVERCLOSED BY
3.81143E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3008 IS OVERCLOSED BY
4.82482E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3036 IS OVERCLOSED BY
3.09163E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3050 IS OVERCLOSED BY
4.30251E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4372 IS OVERCLOSED BY
222.526E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4393 OPENS BY
-9.95364E-15 WITH A CONTACT PRESSURE/FORCE OF -402.426E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3190 IS OVERCLOSED BY
3.46775E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3192 OPENS BY
685.653E-18 WITH A CONTACT PRESSURE/FORCE OF -4.09252E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3188 IS OVERCLOSED BY
3.85005E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4342 IS OVERCLOSED BY
5.82748E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4166 OPENS BY
-7.17313E-15 WITH A CONTACT PRESSURE/FORCE OF -23.3085E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4332 IS OVERCLOSED BY
4.35491E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4131 IS OVERCLOSED BY
3.36176E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4496 OPENS BY
-7.18042E-15 WITH A CONTACT PRESSURE/FORCE OF -3.14076E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4500 IS OVERCLOSED BY
9.01444E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4197 IS OVERCLOSED BY
4.21099E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4311 OPENS BY
-1.44836E-15 WITH A CONTACT PRESSURE/FORCE OF -1.63128E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4357 OPENS BY
1.25456E-15 WITH A CONTACT PRESSURE/FORCE OF -144.153E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4371 OPENS BY
-4.43480E-15 WITH A CONTACT PRESSURE/FORCE OF -708.595E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4385 OPENS BY
-10.5951E-15 WITH A CONTACT PRESSURE/FORCE OF -645.154E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3144 IS OVERCLOSED BY
1.25888E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3105 IS OVERCLOSED BY
2.98047E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3170 IS OVERCLOSED BY
2.30197E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3092 IS OVERCLOSED BY
3.36501E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3196 IS OVERCLOSED BY
245.022E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3203 IS OVERCLOSED BY
6.86887E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3205 OPENS BY
-3.28963E-15 WITH A CONTACT PRESSURE/FORCE OF -10.4804E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3209 IS OVERCLOSED BY
221.849E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4175 OPENS BY
-5.48749E-15 WITH A CONTACT PRESSURE/FORCE OF -6.78829E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4205 OPENS BY
-12.8074E-15 WITH A CONTACT PRESSURE/FORCE OF -2.07014E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4508 IS OVERCLOSED BY
10.6451E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2954 IS OVERCLOSED BY
4.74633E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4377 IS OVERCLOSED BY
10.7485E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4114 IS OVERCLOSED BY
3.20373E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3066 IS OVERCLOSED BY
1.37051E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3222 IS OVERCLOSED BY
279.945E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.448 IS OVERCLOSED BY
822.407E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4214 IS OVERCLOSED BY
5.19124E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4514 IS OVERCLOSED BY
16.8429E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4517 IS OVERCLOSED BY
5.72403E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2969 IS OVERCLOSED BY
2.12095E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2997 IS OVERCLOSED BY
11.7416E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.401 OPENS BY
-8.68519E-15 WITH A CONTACT PRESSURE/FORCE OF -22.2151E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3011 IS OVERCLOSED BY
4.56855E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3039 IS OVERCLOSED BY
672.969E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4369 IS OVERCLOSED BY
7.42781E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4321 OPENS BY
-2.68595E-15 WITH A CONTACT PRESSURE/FORCE OF -2.40882E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3211 IS OVERCLOSED BY
345.139E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3235 IS OVERCLOSED BY
1.62052E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3237 IS OVERCLOSED BY
1.83995E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4519 IS OVERCLOSED BY
6.50769E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4520 IS OVERCLOSED BY
13.5352E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4521 OPENS BY
-15.4585E-15 WITH A CONTACT PRESSURE/FORCE OF -504.077E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4522 IS OVERCLOSED BY
16.2517E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4523 IS OVERCLOSED BY
14.4201E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4211 IS OVERCLOSED BY
537.615E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4316 IS OVERCLOSED BY
1.11711E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2998 IS OVERCLOSED BY
8.41951E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4094 IS OVERCLOSED BY
3.19135E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3068 OPENS BY
-390.506E-18 WITH A CONTACT PRESSURE/FORCE OF -13.6093E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3250 IS OVERCLOSED BY
1.65169E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4527 IS OVERCLOSED BY
4.14780E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4235 IS OVERCLOSED BY
7.61035E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4228 IS OVERCLOSED BY
6.91547E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4218 IS OVERCLOSED BY
3.98762E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2971 IS OVERCLOSED BY
5.27256E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.403 OPENS BY 7.02777E-15
WITH A CONTACT PRESSURE/FORCE OF -10.1028E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2999 IS OVERCLOSED BY
2.46016E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3055 IS OVERCLOSED BY
1.27741E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4353 IS OVERCLOSED BY
9.20193E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4083 IS OVERCLOSED BY
6.28168E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3187 IS OVERCLOSED BY
1.43989E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3200 IS OVERCLOSED BY
1.86942E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3109 IS OVERCLOSED BY
354.994E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3213 IS OVERCLOSED BY
334.384E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3239 IS OVERCLOSED BY
243.168E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3096 OPENS BY
5.03648E-15 WITH A CONTACT PRESSURE/FORCE OF -62.8550E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3263 OPENS BY
928.619E-18 WITH A CONTACT PRESSURE/FORCE OF -5.32687E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4160 OPENS BY
3.34695E-15 WITH A CONTACT PRESSURE/FORCE OF -7.23367E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4243 IS OVERCLOSED BY
14.7882E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4536 IS OVERCLOSED BY
9.65192E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4537 OPENS BY
-14.6348E-15 WITH A CONTACT PRESSURE/FORCE OF -7.36096E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4221 IS OVERCLOSED BY
5.43424E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4219 IS OVERCLOSED BY
2.31568E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4227 OPENS BY
-3.55607E-15 WITH A CONTACT PRESSURE/FORCE OF -7.19412E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4324 IS OVERCLOSED BY
7.04777E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4542 IS OVERCLOSED BY
3.95783E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3000 IS OVERCLOSED BY
2.47359E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3014 IS OVERCLOSED BY
1.02588E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3042 OPENS BY
1.87524E-15 WITH A CONTACT PRESSURE/FORCE OF -33.5907E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4345 OPENS BY
-10.0387E-15 WITH A CONTACT PRESSURE/FORCE OF -148.248E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4082 IS OVERCLOSED BY
2.22827E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3274 IS OVERCLOSED BY
1.63284E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3276 OPENS BY
942.612E-18 WITH A CONTACT PRESSURE/FORCE OF -10.8325E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3266 IS OVERCLOSED BY
8.29268E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4163 IS OVERCLOSED BY
328.670E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4210 IS OVERCLOSED BY
986.305E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4246 IS OVERCLOSED BY
5.17204E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4230 IS OVERCLOSED BY
4.63060E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4220 IS OVERCLOSED BY
2.45730E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4229 IS OVERCLOSED BY
1.64236E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.405 IS OVERCLOSED BY
255.485E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2973 IS OVERCLOSED BY
4.85392E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3001 OPENS BY
-1.09392E-15 WITH A CONTACT PRESSURE/FORCE OF -20.7785E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.653 IS OVERCLOSED BY
10.1066E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4072 IS OVERCLOSED BY
4.77705E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4091 OPENS BY
3.76662E-15 WITH A CONTACT PRESSURE/FORCE OF -1.36401E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3668 IS OVERCLOSED BY
331.189E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3540 IS OVERCLOSED BY
874.297E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3555 IS OVERCLOSED BY
1.08030E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3563 IS OVERCLOSED BY
1.60669E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3571 OPENS BY
1.38131E-15 WITH A CONTACT PRESSURE/FORCE OF -11.9022E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3673 OPENS BY
23.5397E-15 WITH A CONTACT PRESSURE/FORCE OF -234.788E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3286 OPENS BY
1.64505E-15 WITH A CONTACT PRESSURE/FORCE OF -15.8757E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3288 IS OVERCLOSED BY
969.494E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3289 IS OVERCLOSED BY
1.44265E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4551 OPENS BY
1.18497E-15 WITH A CONTACT PRESSURE/FORCE OF -6.06894E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2974 IS OVERCLOSED BY
1.64330E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3044 OPENS BY
2.78731E-15 WITH A CONTACT PRESSURE/FORCE OF -13.0723E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4330 IS OVERCLOSED BY
4.72751E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4331 IS OVERCLOSED BY
979.501E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4118 IS OVERCLOSED BY
1.57938E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4090 IS OVERCLOSED BY
975.833E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3577 OPENS BY
2.43513E-15 WITH A CONTACT PRESSURE/FORCE OF -6.63163E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3597 IS OVERCLOSED BY
1.21626E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3298 IS OVERCLOSED BY
208.820E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3296 IS OVERCLOSED BY
2.67032E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3301 IS OVERCLOSED BY
2.28216E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.440 IS OVERCLOSED BY
1.37296E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4171 IS OVERCLOSED BY
404.368E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4559 OPENS BY
5.45225E-15 WITH A CONTACT PRESSURE/FORCE OF -12.6976E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.595 OPENS BY
-712.176E-18 WITH A CONTACT PRESSURE/FORCE OF -19.8334E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4561 IS OVERCLOSED BY
18.8785E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4566 IS OVERCLOSED BY
15.3941E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3470 IS OVERCLOSED BY
5.69229E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4070 OPENS BY
1.12525E-15 WITH A CONTACT PRESSURE/FORCE OF -2.11333E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4108 IS OVERCLOSED BY
1.20923E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4338 OPENS BY
-495.980E-18 WITH A CONTACT PRESSURE/FORCE OF -1.14154E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3513 IS OVERCLOSED BY
1.34974E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3538 IS OVERCLOSED BY
835.054E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3483 OPENS BY
25.1678E-15 WITH A CONTACT PRESSURE/FORCE OF -329.960E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3596 IS OVERCLOSED BY
1.23756E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3312 OPENS BY
1.69379E-15 WITH A CONTACT PRESSURE/FORCE OF -21.0900E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3311 IS OVERCLOSED BY
1.12927E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3314 IS OVERCLOSED BY
306.203E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3603 IS OVERCLOSED BY
1.09121E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3305 OPENS BY
-3.32954E-15 WITH A CONTACT PRESSURE/FORCE OF -12.9663E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3825 OPENS BY
4.05718E-15 WITH A CONTACT PRESSURE/FORCE OF -24.3720E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4269 IS OVERCLOSED BY
1.34451E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4267 OPENS BY
11.2725E-15 WITH A CONTACT PRESSURE/FORCE OF -72.9546E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.408 IS OVERCLOSED BY
2.13059E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2976 OPENS BY
7.23586E-15 WITH A CONTACT PRESSURE/FORCE OF -34.2381E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2990 IS OVERCLOSED BY
1.03431E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4053 IS OVERCLOSED BY
1.17921E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4068 IS OVERCLOSED BY
4.86561E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4078 OPENS BY
-4.13948E-15 WITH A CONTACT PRESSURE/FORCE OF -2.46001E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4087 IS OVERCLOSED BY
1.92890E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4097 IS OVERCLOSED BY
6.30334E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3666 IS OVERCLOSED BY
5.97756E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3464 IS OVERCLOSED BY
3.56528E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3589 OPENS BY
3.39147E-15 WITH A CONTACT PRESSURE/FORCE OF -11.1484E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3324 IS OVERCLOSED BY
1.17794E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3329 OPENS BY
2.15100E-15 WITH A CONTACT PRESSURE/FORCE OF -4.87915E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3619 IS OVERCLOSED BY
2.30646E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3611 IS OVERCLOSED BY
2.38242E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3318 OPENS BY
-2.49070E-15 WITH A CONTACT PRESSURE/FORCE OF -4.39499E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.470 IS OVERCLOSED BY
10.8798E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3860 IS OVERCLOSED BY
1.86955E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3797 OPENS BY
-1.14601E-15 WITH A CONTACT PRESSURE/FORCE OF -1.21655E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.598 IS OVERCLOSED BY
530.460E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4577 OPENS BY
973.270E-18 WITH A CONTACT PRESSURE/FORCE OF -3.32007E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3888 IS OVERCLOSED BY
3.32568E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3897 IS OVERCLOSED BY
4.28572E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4581 IS OVERCLOSED BY
11.2645E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.409 IS OVERCLOSED BY
1.56147E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.2977 IS OVERCLOSED BY
881.990E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3005 OPENS BY
3.62836E-15 WITH A CONTACT PRESSURE/FORCE OF -8.57352E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3447 IS OVERCLOSED BY
2.64887E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.615 IS OVERCLOSED BY
3.27115E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4061 OPENS BY
-388.784E-18 WITH A CONTACT PRESSURE/FORCE OF -4.41327E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.611 IS OVERCLOSED BY
864.803E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.537 OPENS BY 1.56143E-15
WITH A CONTACT PRESSURE/FORCE OF -10.8346E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4067 IS OVERCLOSED BY
9.56256E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4337 IS OVERCLOSED BY
10.9347E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3516 OPENS BY
13.5912E-15 WITH A CONTACT PRESSURE/FORCE OF -65.6362E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3508 IS OVERCLOSED BY
33.6128E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3558 IS OVERCLOSED BY
3.08304E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3593 OPENS BY
3.93901E-15 WITH A CONTACT PRESSURE/FORCE OF -40.4339E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3340 IS OVERCLOSED BY
817.827E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3335 IS OVERCLOSED BY
4.65652E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3342 OPENS BY
4.34353E-15 WITH A CONTACT PRESSURE/FORCE OF -16.9593E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3626 IS OVERCLOSED BY
2.00331E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3744 IS OVERCLOSED BY
2.62101E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4280 IS OVERCLOSED BY
9.64132E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.599 IS OVERCLOSED BY
2.32642E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4279 IS OVERCLOSED BY
8.37576E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.600 OPENS BY 12.0395E-15
WITH A CONTACT PRESSURE/FORCE OF -25.7586E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3906 IS OVERCLOSED BY
4.04985E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4585 OPENS BY
5.67847E-15 WITH A CONTACT PRESSURE/FORCE OF -2.08707E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4590 IS OVERCLOSED BY
12.1023E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.609 IS OVERCLOSED BY
9.19083E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3726 OPENS BY
9.26917E-15 WITH A CONTACT PRESSURE/FORCE OF -22.9872E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3717 OPENS BY
6.68261E-15 WITH A CONTACT PRESSURE/FORCE OF -40.2502E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3524 IS OVERCLOSED BY
2.30514E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3527 IS OVERCLOSED BY
4.83746E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3674 IS OVERCLOSED BY
3.61635E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3440 IS OVERCLOSED BY
1.89610E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3441 OPENS BY
6.73388E-15 WITH A CONTACT PRESSURE/FORCE OF -73.7520E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3355 OPENS BY
2.75783E-15 WITH A CONTACT PRESSURE/FORCE OF -17.6687E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3350 OPENS BY
1.40000E-15 WITH A CONTACT PRESSURE/FORCE OF -3.13226E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3348 OPENS BY
-2.04595E-15 WITH A CONTACT PRESSURE/FORCE OF -8.66012E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3632 IS OVERCLOSED BY
941.490E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3681 IS OVERCLOSED BY
1.92409E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3840 OPENS BY
4.88721E-15 WITH A CONTACT PRESSURE/FORCE OF -44.3658E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3813 OPENS BY
16.2962E-15 WITH A CONTACT PRESSURE/FORCE OF -111.444E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3849 OPENS BY
8.19000E-15 WITH A CONTACT PRESSURE/FORCE OF -61.5402E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3858 OPENS BY
6.60291E-15 WITH A CONTACT PRESSURE/FORCE OF -17.7035E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3770 IS OVERCLOSED BY
6.63836E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3734 IS OVERCLOSED BY
1.56357E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3867 IS OVERCLOSED BY
3.08627E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3886 IS OVERCLOSED BY
3.56665E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4598 IS OVERCLOSED BY
14.4173E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.411 OPENS BY
-1.72759E-15 WITH A CONTACT PRESSURE/FORCE OF -30.0515E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3425 IS OVERCLOSED BY
656.518E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.571 OPENS BY
-9.77341E-15 WITH A CONTACT PRESSURE/FORCE OF -10.0934E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3435 IS OVERCLOSED BY
3.91825E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.509 IS OVERCLOSED BY
3.27550E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3639 IS OVERCLOSED BY
555.248E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.479 IS OVERCLOSED BY
1.00169E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3933 IS OVERCLOSED BY
3.57580E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.563 OPENS BY 1.54365E-15
WITH A CONTACT PRESSURE/FORCE OF -28.8011E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4297 IS OVERCLOSED BY
2.14316E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4600 IS OVERCLOSED BY
9.71181E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4601 IS OVERCLOSED BY
10.3811E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3876 OPENS BY
4.73075E-15 WITH A CONTACT PRESSURE/FORCE OF -97.4097E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.4605 IS OVERCLOSED BY
21.5088E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.607 IS OVERCLOSED BY
4.92137E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3698 IS OVERCLOSED BY
2.52202E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3499 IS OVERCLOSED BY
8.60636E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3475 IS OVERCLOSED BY
3.88969E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3620 OPENS BY
1.77559E-15 WITH A CONTACT PRESSURE/FORCE OF -30.3603E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3379 OPENS BY
1.26075E-15 WITH A CONTACT PRESSURE/FORCE OF -13.9252E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3376 OPENS BY
-595.914E-18 WITH A CONTACT PRESSURE/FORCE OF -5.62546E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3375 OPENS BY
-3.06293E-15 WITH A CONTACT PRESSURE/FORCE OF -17.4830E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3374 IS OVERCLOSED BY
5.27604E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3372 IS OVERCLOSED BY
724.975E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3371 OPENS BY
4.38776E-15 WITH A CONTACT PRESSURE/FORCE OF -6.31780E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3759 IS OVERCLOSED BY
4.27468E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3829 OPENS BY
4.92624E-15 WITH A CONTACT PRESSURE/FORCE OF -64.1572E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3811 OPENS BY
1.98032E-15 WITH A CONTACT PRESSURE/FORCE OF -28.3632E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3802 IS OVERCLOSED BY
1.01922E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3793 IS OVERCLOSED BY
1.87503E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3856 IS OVERCLOSED BY
4.43561E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3766 IS OVERCLOSED BY
6.36427E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3903 IS OVERCLOSED BY
378.887E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3912 OPENS BY
6.23515E-15 WITH A CONTACT PRESSURE/FORCE OF -7.67210E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3865 IS OVERCLOSED BY
1.45638E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3409 IS OVERCLOSED BY
1.36398E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3415 IS OVERCLOSED BY
185.399E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3705 OPENS BY
8.93551E-15 WITH A CONTACT PRESSURE/FORCE OF -15.3163E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3696 IS OVERCLOSED BY
2.76099E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3687 IS OVERCLOSED BY
1.96634E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.531 OPENS BY 2.28240E-15
WITH A CONTACT PRESSURE/FORCE OF -19.8559E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3491 IS OVERCLOSED BY
7.83706E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3476 IS OVERCLOSED BY
1.94892E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3501 OPENS BY
-5.32602E-15 WITH A CONTACT PRESSURE/FORCE OF -20.9548E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3827 IS OVERCLOSED BY
1.01017E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3836 OPENS BY
6.15620E-15 WITH A CONTACT PRESSURE/FORCE OF -27.3115E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3459 IS OVERCLOSED BY
369.076E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3872 OPENS BY
2.96383E-15 WITH A CONTACT PRESSURE/FORCE OF -1.23908E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3890 IS OVERCLOSED BY
1.17572E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3926 IS OVERCLOSED BY
2.45518E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3394 OPENS BY
1.53609E-15 WITH A CONTACT PRESSURE/FORCE OF -9.11702E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3627 IS OVERCLOSED BY
2.06471E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.477 IS OVERCLOSED BY
8.30957E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3713 OPENS BY
-1.65092E-15 WITH A CONTACT PRESSURE/FORCE OF -33.8745E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.370 OPENS BY 5.82819E-15
WITH A CONTACT PRESSURE/FORCE OF -68.6190E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3978 OPENS BY
2.75739E-15 WITH A CONTACT PRESSURE/FORCE OF -36.7338E-18 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3987 OPENS BY
5.76248E-15 WITH A CONTACT PRESSURE/FORCE OF -22.9621E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3968 IS OVERCLOSED BY
4.54794E-15.
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3921 OPENS BY
9.25366E-15 WITH A CONTACT PRESSURE/FORCE OF -36.9378E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3874 OPENS BY
3.70103E-15 WITH A CONTACT PRESSURE/FORCE OF -19.8106E-15 .
LINER-1_LINER_INTERNAL) NODE RESIDUUM-BONE CUTOUT-1.3883 OPENS BY
7.52192E-15 WITH A CONTACT PRESSURE/FORCE OF -71.9763E-15 .
" A picture is worth thousand words"
If you post some pictures, it would be helpful to understand the problem. I am not aware about the biomechanics analysis but let me give you general points to achieve convergence.
[ul]
[li]Increase steps of the analysis. For contact analysis, its better to first establish contact in the initial steps and then apply loading. To establish contact use displacement loads. For the two parts to be contacted, move one part with very small displacement like 0.01/0.1. This is to tell Abaqus there is contacts between parts.( Abaqus/or any FEA software is not smart enough, I guess.[wink]) At later step, deactivate/remove the displacement load and apply small load (10%) and in next step apply full load.[/li]
[/ul]
[ul]
[li]Refine mesh at penetration locations. Most of the problems in contact convergence are solved by refining the mesh at the master as well as slave surface. Use of linear brick/quadratic tet is always recommended. Contact with linear brick elements is smooth but not so with quadratic tet. For different material properties different elements are recommended. Check which elements is suitable for your analysis in Abaqus manual or example problems. Link-1 and Link-2. [/li]
[/ul]
[ul]
[li]Use contact stabilization. this will apply the damping force to counter large contact force application locally at the contact. But make sure the damping energy (ALLSD) is very less number than internal energy of the model (ALLIE). (Its not always recommended, though)[/li]
[/ul]
[ul]
[li]Use step stabilization. This will introduce the damping forces to counter large contact force application and will slowly apply contact forces/assembly loads to achieve convergence at complete part/assembly level. But make sure the damping energy (ALLSD) is very less number than internal energy of the model (ALLIE). (Its not always recommended, though)[/li]
[/ul]
[ul]
[li]Sometimes its better to use general contact than surface to surface contact. I feel general contact algorithm is robust than the surface to surface contact. But if model size is too big then this may get warnings of memory exceeded. Give it a try.[/li]
[/ul]
[ul]
[li]Sometimes changing step initial increment size has also help achieve contact convergence. Some problems are solved by 0.1/0.01/0.001 initial increment size and some problems are solved by initial increment of 0.1/0.2/0.5/1.[/li]
[/ul]
More tips on contact convergence on - Link-1, Link-2 and about vol. flux Link-3. Or just google "contact convergence in Abaqus" and "your specific error/warnings".
Hope this helps.
It would be best if you could share the files (inp or cae) but maybe pictures will suffice.
This simulation is really complex and it would be best to simplify it gradually and observe at which point the problems occur. For example, you could replace some contacts with tie constraints to see which surface pairs are problematic.
There’s an interesting article titled "Simulation of a Parking Pawl Mechanism with Abaqus/Standard and Abaqus/Explicit" by D. Ramnath et al. Authors described various ways to handle contact convergence issues in Abaqus. Another article, this time entirely focused on this topic, is titled "Getting Bodies into Contact - the Despair and Joy" and written by R.J. Tyrrell.
