Contact US
API 653 applicable edition
Hi, I have a query on API 653.
If I am currently inspecting a tank built to API-650, which edition of API-653 should I use for inspection and repair?
Should I use the latest edition of API-653?
RE: API 653 applicable edition
Most API Standards will refer to other relative standards in their preface and/or opening sections.
Common Sense tells us that the latest available standard should be used. Although a purchase orders conditions may state otherwise.
*** Per ISO-4126, the generic term 'Safety Valve' is used regardless of application or design ***
*** 'Pressure-relief Valve' is the equivalent ASME/API term ***
Quote (Andres Romero
...If I am currently inspecting a tank built to API-650, which edition of API-653 should I use for inspection and repair?)
You are expected to follow the latest edition of the standard unless if the client requirement is a different edition.
As the honorable HTURKAK said, you inspect per the latest edition of API 653.
I would evaluate the tank to the latest edition of API 650 and also to the standard that the tank was built to (or repaired). If there are meaningful differences between the current API 650 and the standard that the tank was built to (or repaired), bring those issues to the attention of the owner especially if they are safety or performance related.
In the case of conflicts between the requirements of API 653 and the as-built standard (API 650
or its predecessor API 12C), API 653 governs.
If the as-built standard is unknown, use API 650 in effect at the time the tank was built (or repaired). If the date the tank was built (or repaired) is unknown, use the current edition of API 650.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
