WINDCHILL task
Windchill Creo
IN
I have a task to revise the PDF document that exist in Windchill, "revision number" need to match with the respective WT part. Here PDF/WT parts number are same.
My requirement:
I have list of all pdf document number need to be updated.
If PDF document revision matches with the WT part then "no change required" else revision need to done on PDF document.
Is it possible to automate this task
If you are a Windchill admin with significant SQL and Windchill development experience it's easy.
If not, record all the steps required and then use some automation tool, like AutoIt or AutoHotKey, to do this.
Thank you for your sugesstion and quuick reply
