Placement of No-Fines Concrete Under Water
Does anyone have experience with no-fines concrete when tremie placed underwater? We have a situation where the owner (the State) would like to fill the void between a new bulkhead and an old bulkhead with concrete. We are worried about large differential water levels if the void was filled with traditional concrete. Are there issues with maintaining the drainage function of the no-fines concrete when tremie placed under water?
RE: Placement of No-Fines Concrete Under Water
Well if you place no-fines concrete under water you're basically just placing a more expensive version of crushed stone anyway.
I'd make sure there isn't some type of load test or inspection after placement, since what you place in this scenario isn't going to behave much different than crushed stone (ie you're not going to get the structural performance of concrete)
Haha yeah, I fully understand what I was saying. Sounds like the folks requiring this are inexperienced with SSP bulkheads. We hope to educate them before they piss my tax dollars down the drain.
There won't be any load test. It is simply a void filling application and is not structural. I'm just looking to find a loophole in case they further dig the heals in on using concrete.
however, gravel easily flows into all the nooks and crannys and will adjust if there is any future settlement or movement of the subgrade or the old bulkhead. weak concrete wont do that
