Contact US
moment connection in structural members
Hello guys,
I understand that if the beam being used is I beam/W beam then in order to achieve moment connection(fixed connection),
both web and flange of I/W beam needs to be connected & for shear connection (Pinned) I only need to attach the web.
As the structures I work with are not under heavy loading, Previous engineers used C channel, angle, HSS sometimes as beams.
If those are being used as beam, what are ways to achieve shear and moment connection?
Thank You
Newbie
RE: moment connection in structural members
Not correct, you have to connect for both moment and shear... they are both different 'critters'.
For connecting beams and channels, for shear you can use clip angles, for moment and shear it's best to use end plates.
@Dik,
Sorry I do not understand. My question is :
As we commonly have S beams and whenever we have a moment connection, We use end plate connection. End plate is welded to beam(both flange and web of beam are welded to end plate). Now end plate is bolted/welded to column.
My question is If someone wants to use HSS/angle/c channel instead of S or other structural member. How do we make a moment connection?
Thank You
The top left detail in kipfoots link is most common in these environs, else a plate welded to the HSS section to attach a bolted end plate is also common. HSS with end plate is common as well as C section is often connected with clip angles. An angle is often connected to a simple fin plate welded to the face of the HSS for small loads.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
