What are certifications required to
What are certifications required to become a QA/QC mechanical inspector(Static & rotating equipment + piping)?
RE: What are certifications required to
In the USA
For piping, API 570
For pressure vessels, API 510
For Tanks, API 653
Not sure on rotating equipment.
The devil is in the details; she also wears prada.
In the EU: none, afaik. There are however some genera courses in welding engineering and welding inspection which provide valuable background to most fields in pressure equipment.
IWP
IWS
IWT
IWE
IWI, various levels. Comparable to CSWIP
Huub
- You never get what you expect, you only get what you inspect.
All Inspectors shall be qualified in accordance with ASME QAI-1.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
