General Section - Are designed in SAP2000
X4vier
CO
I think this forum isn't popular but in any case:
Can SAP2000 design "General Sections". General Sections are in which one defines his properties directly.
Thanks.
By "design" I assume you mean "performing strength checks per a design standard."
If so, then no. SAP2000 will need to know lots of details about the section. For one of dozens of examples: if the member is steel, then does the section have any slender compression elements?
