How do I solve for displacements after getting my stiffness matrix [K]?
I've written a Matlab program that creates a global stiffness matrix for a group of Q8 elements.
I have a force vector, now I'm trying to apply boundary conditions and solve for the displacements. The problem I've run into, is whether I eliminate rows and columns correlated to Dof's that equal 0 or if I
use lagrangians I end up with a singular K matrix that can't solve the system using backdivide.
Whats the best way to implement boundary conditions and solve for the displacements after obtaining global stiffness?
RE: How do I solve for displacements after getting my stiffness matrix [K]?
Right now I'm running the program on a single Q8 element. Each node has two in plane translational Dof's. I've constrained the bottom three nodes in both directions, and applied a load on the top right corner of the Q8, acting laterally. I feel like the model would be constrained, could you offer any insight into how to constrain it properly?
Was this element's formulation taken from some Matlab library or defined from scratch by you ?
There are two books that can be particularly useful for you:
- "Introduction to Finite Element Analysis Using Matlab and Abaqus" A. Khennane
- "The Finite Element Method Using Matlab" Y.W. Kwon, H. Bang
They discuss plane stress/strain elements as well (especially the first one may help).
Thanks for recomending those books, had one of them on my wishlist already.
