Contact US
A loop in Abaqus python script in odb file.... to get the data of all the frames at a time
Hello Everyone,
I created the abaqus python script to get the stresses data in a particular frame but i would like to obtained all the data of stresses for All frames at a time by using loops ....Can someone help me how could i modify my abaqus python script.... code attached
db = session.odbs['file name']
session.writeFieldReport(
fileName=',
append=ON, sortItem='Node Label', odb=odb, step=0, frame=12,
outputPosition=NODAL, variable=(('COORD', NODAL, ((COMPONENT, 'COOR1'),
(COMPONENT, 'COOR2'), (COMPONENT, 'COOR3'), )), ('S',
INTEGRATION_POINT, ((INVARIANT, 'Mises'), (COMPONENT, 'S11'), (
COMPONENT, 'S22'), (COMPONENT, 'S33'), (COMPONENT, 'S12'), (COMPONENT,
'S13'), (COMPONENT, 'S23'), )), ), stepFrame=SPECIFY )
RE: A loop in Abaqus python script in odb file.... to get the data of all the frames at a time
In Abaqus scripting, you can use "for" loops like you normally would in Python codes. This way it's possible to loop through elements, nodes or frames like in this case. The use of loops in Abaqus postprocessing scripts is presented in the article "Automate boring postprocessing in Abaqus using python scripting" on Simuleon blog, that might be a good starting point for you (apart from the documentation of course).
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
