Bolt Preload calculation for a 2 side threaded bolt
I need to find the bolt preload for a 2 side threaded bolt. Could some one help me how to find the preload.
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Bolt Preload calculation for a 2 side threaded bolt
The bolt preload is uniform throughout the stud imagine you put one end in a tapped hole and at the other end you tighten a nut against a member face, the thread in the tapped hole sees the same tension as the threaded part in the nut.
We can’t help you any more than that because you haven’t given any info, ie size and length of stud, material and or application of the stud.
David
Mechanical project manager
JLFY technology company
Https://www.customized-tech.com
