This keyword is not available on this platform
I am having troubles for analysis.
After applying "analyse entire model", this message appears:
Files from a previous analysis conflict with the current job name: "modal_frquency_job". These files are modal_frquency_job.bdf. Will you permit deletion of these files?
I click Yes button, then cmd window appears for like 0.1 seconds and nothing happens. I cannot access results. PATRAN does not generate .h5,.log,.f06,.f04 files, only .jou file is generated.
I hardly succeeded to take a screenshot of the error https://prnt.sc/21pmeme (bend is one of my files, this error occurs at every file)
Files: https://drive.google.com/drive/folders/1r7TOJN5yPt...
All of my files were running succesfully till today, now none of them is running. What should I do?
Is it beacuse I once downloaded SQLite and its extension was .db too? I changed .db files for PATRAN as "open with notebook". I did not face with this problem when I did that. It just happened today.
RE: This keyword is not available on this platform
