Contact US
SS Steel Corrosion
5
SS Steel Corrosion
SS Steel Corrosion
Hi all,
Is there any solution for corrosion in SDS pipes and SDS pump casings other than pickling and passivation?
RE: SS Steel Corrosion
We need more information than that.
What is the service, materials, type of corrosion.
Help us out here.
SDS - Safety Data Sheet, of course! (Answer may be influenced by one of my current work assignments...)
Pardon me. I was referring to Super Duplex Steel.
Service: Filtered sea water
Material: Super Duplex Stainless Steel
Affected Equipment: 1. Pump casings(material EN 1.4469 (similar to ASTM A890 Grade 5A))
2. Interconnecting Piping( Super Duplex and SS 316)
Type: Seams like localized pitting corrosion in case of pumps. In pipes pitting is observed especially in HAZ.
Attached file contains photos for reference.
Quote (SDS - Safety Data Sheet, of course!)
We do that one better... MSDS; now, I know what you're talking about.ponder
MSDS no longer exist!!! Replaced with SDS in 2015....
Were the pump casting tested per ASTM A923?
It may be something, or it may be nothing.
Those are all external, where they see deposits of salt on the surface.
If they were ever handled or touched with steel tools then I would expect to see rust spots everywhere.
And the 316 is hopeless, it will not tolerate seawater, period.
Do you have leaks?
Have you opened anything up to see if this is more than cosmetic?
You guys are way ahead of me; I'm still trying to work out what SS Steel' refers to hourglass
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Would be ideal if one of the corroded sections from either the pipe or casing could be removed and evaluated in a metals laboratory to determine corrosion mode and likely cause. I sometimes have been given samples that appeared to have scattered pitting corrosion that turned out to instead have occurred from a different mechanism (these have included stress corrosion cracking and MIC, but I really don't want to put speculative ideas out there as this could be something else altogether).
Appears to me as if the pipe sections were laid on and dragged across a steel bed of sorts as well as cross contamination from buffing/grinding/cutting discs. Weld spatter as well would easily cause some of those marks. Some sections appear to be more corroded than others so it's likely old material that's been sitting around or was just mishandled was used.
Thanks, David...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
