Contact US
NODE SET ASSEMBLY__PICKEDSET HAS NOT BEEN DEFINED - can anyone help?
Hi people, can anybody help?
I'm quite new to Abaqus..doing some 3 points bending test. When I set penetrator movement as displacement everything works properly but when I place a force to an RP (penetrator is defined as a rigid body) it's constantly popping up the error: NODE SET ASSEMBLY__PICKEDSET35 HAS NOT BEEN DEFINED.
Whatever I did in terms of adjusting/changing in parameters, it's still there.
Cheers
RE: NODE SET ASSEMBLY__PICKEDSET HAS NOT BEEN DEFINED - can anyone help?
Redefine this node set or manually pick the reference point in load definition. Check all warning messages, they can point you to the actual cause of the problem.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
