Know of Shell Element Formulations with Differential Stiffness Matrix?
Does anyone of know shell element formulations (tri and quad) that have an associated differential stiffness matrix (geometric stiffness matrix)? The MITC elements are quite popular, but we can not find the associated differential stiffness matrix. The objective is to incorporate these formulations so we can do buckling analysis for the MYSTRAN project. This is probably the most lacking aspect of MYSTRAN at this point. Alternatively, does anyone know how to derive a differential stiffness matrix from an existing shell formulation (this way we could use the MITC shell as the base since it has a published formulation).
Brian
www.mystran.com
Brian
www.mystran.com
RE: Know of Shell Element Formulations with Differential Stiffness Matrix?
DG
I wrote an article a year ago about the MITC element, it may help for your application (you can refer to thread727-468911: Truss, beam and MITC4 element formulations). You can also consult the original paper about the MITC4 element, it discusses the large displacement derivation from where you should be able to derive the geometric stiffness matrix.
Ali
