Costs of Painting versus Grit blasting
We currently have some aluminum die castings that are painted silver after machining solely for appearance. We're thinking it might be a cost reduction to grit-blast instead of painting as the end result would look similar, and in use the paint wears off in a short time anyway.
Parts would need cleaning either way, and painting vs blasting is similar in that some piece of equipment is spraying the part, so the pre-treatment for painting is where the savings would come from. Is this reasonable thinking? Any fails or pitfalls we should be watchful for?
Thanks in advance...
Bob
Bob
RE: Costs of Painting versus Grit blasting
So the overall cost would not be much different!
* Finding a solution is great * Knowing how to implement it is fantastic * Believing it is the only one and best is naive ?
