CVN from AWS D1.1 Qualification requirements for Thickness
Hi Everyone, I have a PQR with 6GR Position with Thickness 10 mm as per AWS D1.1 2015, my question is if I need to weld a plate with Thickness 5mm will need to have a new PQR due to thickness, which CVN is Mandatory
RE: CVN from AWS D1.1 Qualification requirements for Thickness
Open D1.1 and have a look.
Took me about 1 minute to get the answer.
As noted on here many times previously the intent of this forum is to assist when someone cannot find something.
It is obvious you haven't even looked.
Shane
