Epdm gasket thickness
IN
Hi All,
Details:
Flange size: DN2600
Pressure: PN16
Gasket Material: EPDM
Application: Gasket is going to be mounted between DN2600 butterfly valve & pipe Flange.
Doubt:
What thickness of Full face flange Gasket I should select?
The standards EN 1514-1, ASME B16.21 doesn't specify the gasket thickness.
Can anyone pls suggest me with correct thickness value of gasket with their experiences.
