Nov 19, 2021 #1 Lili_A Industrial Joined Nov 19, 2021 Messages 1 Location CL Dear Sirs, kind regards. The question this time is about welding a gusset (connection plate) of fillet weld on the web of the beam over a butt weld joint of 2 beams. Is this correct? https://files.engineering.com/getfile.aspx?folder=edeaa873-a55b-4f80-8f7c-04d4c705833e&file=20211119_103553.jpg
