hello
i m trying to understand this simulation results which i have attached this post.
in the simulation they explained the results (pages 3,4 ) they said that the harmonics is injected by the source source (rectifier) between 0.4-0.6 sec , which you can see on the graph .
i dont understand why the rectifier injected the harmonics between this time frame , i mean if it work , it should injects harmonics as long as it on ??/
