PUMPS inducer question
garciaf
64
My issue is the following
This statament es a suppostion
I have two equual Pumps, But later I decide to modify the suction adding an inducer in one of these pumps,
How the flow would change in these pump.
also if I change the inducer for one bigger, the flow would go up????..
please help
The flow in the pump with the inducer would increase, but by how much is impossible to say as it depends on the non inducer pressure differential.
My guess is very little difference.
My experience is that unless you are cavitating or very nearly so then adding an inducer will not change flow.
In some cases it does increase power required slightly.
