CRUDE OIL DISTILLATION
Does the feed crude oil at the tank have standard temperature of 25 degrees before it goes to the preheater and then to desalter? Little confused on the normal temperature of Crude oils
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: CRUDE OIL DISTILLATION
It may be at 25 degrees CELSIUS if conditioned for transportation to the tank, but it will be warmer when existing a well.
Wrong unit => wrong answer.
* Finding a solution is great * Knowing how to implement it is fantastic * Believing it is the only one and best is naive ?
