Oil flange redesign
Ivan_Torres
Student
Hello Engineers,
I am a senior about to graduate and last thing I need to do is finish my senior design project. Most of my group voted for a redesign of a weld neck flange so that is our project. Through solidworks simulations I found that lowering the hub length decreases the pressure experienced by the flange, therefore having a longer life. But I wanted to find an application for my final presentation, I wanted to know if anyone here has any ideas for a good application for my flange, or something else to bring to my presentation so we don't get torched alive by the faculty for having such a simple project. I would love to hear your ideas!!
Thank you.
The goal of the redesign is to “optimize” the flange, only thing we were able to optimize though is the stress it experiences on the hub by lowering the hub length.
This flange we designed isn’t a specific part on a custom project or any of the sort, it’s just a change to a general flange, finding the application for it is what we’re struggling with.
I doubt anyone would adopt changing the dimensions of standard WN flanges (ASME B16.5 and B16.47) and also just minor adjustments on the hub dimensions.
I highly doubt it as well but we have to make it work at this point, even if it’s a very specific application/scenario.
It seems that the best reason to redesign such a flange is to prevent substitution do to specific environmental exposure risks. I don't know that this is substantial enough to be considered a capstone project.
You can try to sell it as reducing the required length and weight of the flange/equipment - there could be some value in this in niche applications. Think of some applications where this could be useful and hope that your professor doesn't know better.
However, as noted by others, standardized flanges are strongly preferred, and it is unlikely that your short hub flange would ever be used. Getting a custom flange to pass code requirements and convincing customers and regulators to accept it is unlikely to succeed. There are already standardized compact flanges and clamp hubs that are likely preferable to your custom flange if something more compact than a regular flange is required.
One lesson here is to have clear requirements/goals when working on a design. If you simply try to "optimize" without understanding what you're trying to optimize or why, you waste a lot of time and effort.
I'd suggest reviewing your project's requirements with an advisor. Typically undergrad capstones require following the entire development process from business case development through design to basic testing. Without identifying customer-use cases you cant really optimize anything; one type of customer values cost over everything whereas others value different functional requirements, so you end up with multiple "optimized" parts.
Make certain that you understand the required clearances for welder access. Installation may drive the design.
Yeah, ok, this is a great learning opportunity. In Engineering design, as in many things, there is a "cart" and a "horse". A successful project recognizes which part of the project is which and gets them in the right order. "why are we doing this ?" and "how will this be used ?" and "what are we optimizing ?" are questions that should've been asked and answered.
For my money if asked "where will this be employed ?" (which seems to be the question you're asking) either think of some specialized application or (tell the truth) "we cna't think a anything". I doubt the project will be marked down because the problem statement wasn't well thought out.
I understand you've discovered that shortening the "stem" of the valve improves the fatigue of the flange. Ok ...
1) are we experiencing fatigue failures ? (if not, then improving the fatigue life isn't worth anything)
2) what other design aspects are affected by shortening the "stem" ?
3) if we shorten the "stem" then we'll be lengthening the plumbing (the tubes connected to the valve) ... which will offset any weight gains (if that is what you were after).
There is no added value to redesign existing flanges. And the reason is as posted by above of all post. This is standard reliable practice.
Stick to what works and not deviate.
