Need Suggestions on CAD data management without PLM
Greetings...!
I'm using CREO ELEMENTS/PRO-E WF 5.0 at my workplace. Here we don't have a PLM/PDM system. As of now, we are using External Hard Disk for storing the CAD data, apart from local folder copy. Its became a challenging task to trace the latest updated model from the local copy or HDD or from other peer designers. I need your help or suggestions on this matter, is there any better way to organize and structure these CAD files without using PLM software, our company is not ready to invest in PLM. Any help or suggestions would be highly appreciated.
Thanks in advance for your time and support...
Greetings...!
Thanks & Regards,
Sam
RE: Need Suggestions on CAD data management without PLM
Name you files with the part number and revision level: 145265.B.prt
Move released files and drawings to a Released folder.
Store hardware and other common items in their own sub-folders.
Create working directories for your users. Have them copy the files they need to their workspace.
Structure the search paths very carefully so the software loads the right files.
BTW - You are using software that is at least 11 years old! the last release of WF5 was in September 2010.
How much productivity are you losing by not being on later versions?
How much productivity are you losing by not investing in a PLM system to manager your files?
Ben Loosli
I expect the reason for not using a PLM is that the likely one will be Windchill which PTC has clearly designed to be operated by a staff of SQL experts - not a problem when they sell it to multinationals, but too bad for the 5 person shop that the original Intralink was perfect for.
Will try and get back to you
Thanks & Regards,
Sam
The hardest part of Windchill is the initial setup of your contexts, states, roles and ACLS. It is mostly all covered in a Windchill System Administration class. ACLs are the weak point in the training and I did hire a consultant to help finalize what I had setup. Took us less than 20 hours to get it all together and running.
Ben Loosli
I have quite a few products that are still in WF4 even though we also have CREO 6 available. To me, the productivity of WF4 is head and shoulders better than any of versions that use the ribbon interface. Also, PTC destroyed the drawing functionality of the show/erase interface with Creo. Drawing/detailing is still the most time consuming part of the design process and PTC continues to make it harder and harder to do.
One company I worked at used to take 2-D views from Pro/E and paste them into AutoCAD to do their drawings.
When Pro/Engineer was first released, V1 did not even have a drafting module. Drafting did not appear until V3.
Ben Loosli
I have used those in the past at small companies and startups with decent success, but as others have said all it takes is one moron to bring down all the house of cards
THIS SIGNATURE IS INTENTIONALLY BLANK
