Contact US
ABAQUS: Import Stressfield
i would like to know how it is possible to import a Stress field into a similar Model.
I have a Model 1, which is a Beam under a load and as the result the Stress of the Beam. Then there is the second Model 2 with same Beam, same Mesh and boundary conditions. In Addition there are Parts underneath the Beam as reinforcement. I want to have the same Stress in Model 1 and Model 2 for the Beam, but the reinforcement should not be stressed in the beginning(initial). Is there any way to use the results of the Model 1 as initial Input parameters for Model 2?
I tried to use predifined field and import the Stress from the Output Data file of Model 1, but that does not work.
Is there another way to import Stress or this actually the right way?
Cheers.
RE: ABAQUS: Import Stressfield
Check the import capability (*IMPORT keyword). You can transfer the deformed mesh and material state associated with it between Abaqus analyses.
i read that part in Abaqus-docs and i tried a bit of it, but nothing worked. Maybe you can be more precise.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
