batch conversion of CANBUS logged data
pietro82
Automotive
IT
Dear all,
I have tons of CANBUS logs that I have to analyse with Matlab. I have chosen Matlab since I can automate the post-processing. Unfortunately, Matlab seems to have a few limitations in the messages it can import so, in some cases, I have to use another SW for exporting .ASC/.BLF file into .MAT file. I usually use an old version of Vector CANAlyzer which it does not permit batch convert CANBUS logs (for batch conversion I mean the ability to select an entire folder and automatically convert it). Probably, a newer version will permit it, but it is too pricey for my use. Is there any other tool I can use for batch conversion of .ASC file into .MAT or any other file format that can be opened with Matlab? Any suggestion is appreciated.
Thank you.
Best regards,
Pietro
well, if you are up for some programming, here's s description of the file format, and comments that Matlab has an API
"Most MATLAB users do not need to know the internal format of a MAT-file.
Even users who must read and write MAT-files from C and Fortran programs
do not need to know the MAT-file format if they use the MATLAB Application
Program Interface (API). This API shields users from dependence on the
details of the MAT-file format."
Jay
Jay Maechtlen
My previous experience may have been a bit caveman-level, but I found it was possible to rename the .ASC files to .CSV and then make a simple MATLAB code to convert the raw CAN numbers into the signals of interest I was reading.
It was pretty straightforward to have a batch Matlab script load the file, save a copy as the CSV, and then open the CSV's, do the data conversion and save as M files with all the data intact.
Was a little bit of a coding exercise, but if you don't have the right toolboxes I found it was possible to do this way.
