ABAQUS: change sketch of Parts afterwards
J.Realer
Student
DE
Hallo everyone,
i'm using ABAQus for a FE-Simulation.
Is there a chance to change the sketch or the measures of Parts, without redo the input of the section, the assembly and the constraints?
I did a mistake right at the beginning and wondered if, i can just correct the measures of the Part instead of setting up nearly the whole Model again.
It would be nice if you can help me to save time.
Thanks.
Yes, you can edit part's geometry and features should regenerate (as much as possible for a given level of modification). Give it a try.
Thanks. it works just like that.
