Oct 20, 2021 #1 curiousinvite Civil/Environmental Joined Apr 24, 2021 Messages 42 Location AU what is direction 1 and 2? Is it X and Y axis ? what about the spacing shown above, Is it parallel to 1 direction(X axis)?
Oct 20, 2021 1 #2 JoshPlumSE Structural Joined Aug 15, 2008 Messages 10,857 Location US Go to View - Set Display Options. On the Objects tab, there is a section titled Shell Assignments. Check the box that says "local axes". That should allow you to see the local axis direction for your slab. I hope that helps!! Upvote 0 Downvote
