What is direction1 and direction 2? 1
curiousinvite
AU
what is direction 1 and 2?
Is it X and Y axis ?
what about the spacing shown above, Is it parallel to 1 direction(X axis)?
Go to View - Set Display Options.
On the Objects tab, there is a section titled Shell Assignments. Check the box that says "local axes". That should allow you to see the local axis direction for your slab.
I hope that helps!!
