Contact US
How to process all detailviews?
I wanna process all detail views to change label on it. Below is my code, but I receive an error "cannot convert detailview to 1-dimensional array view."
CODE
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
	Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
	Dim workPart As NXOpen.Part = theSession.Parts.Work
	Dim displayPart As NXOpen.Part = theSession.Parts.Display
Sub Main (ByVal args() As String)
	Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
	markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
	'Dim views1(0) As NXOpen.View
	'Dim detailView1 As NXOpen.Drawings.DetailView
	Dim startSheet As Drawings.DrawingSheet = theSession.Parts.Work.DrawingSheets.CurrentDrawingSheet
	'for each views1 as Drawings.DraftingView in startSheet.SheetDraftingViews
	for each dview as NXOpen.Drawings.DetailView in startSheet.SheetDraftingViews
		'views1(0) = detailView1
        'If views1.Name.Contains("DETAIL") Then
		'for each dview as NXOpen.Drawings.DetailView in views1
			Dim editViewSettingsBuilder1 As NXOpen.Drawings.EditViewSettingsBuilder = Nothing
			editViewSettingsBuilder1 = workPart.SettingsManager.CreateDrawingEditViewSettingsBuilder(dview)
			theSession.SetUndoMarkName(markId1, "Settings Dialog")
			Dim editsettingsbuilders1(0) As NXOpen.Drafting.BaseEditSettingsBuilder
			editsettingsbuilders1(0) = editViewSettingsBuilder1
			workPart.SettingsManager.ProcessForMultipleObjectsSettings(editsettingsbuilders1)
			'editViewSettingsBuilder1.ViewDetailLabel.LabelParentDisplay = NXOpen.Drawings.ViewDetailLabelBuilder.LabelParentDisplayTypes.LabelOnBoundary
			Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
			markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Settings")
			theSession.DeleteUndoMark(markId2, Nothing)
			Dim markId3 As NXOpen.Session.UndoMarkId = Nothing
			markId3 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Settings")
			Dim nXObject1 As NXOpen.NXObject = Nothing
			nXObject1 = editViewSettingsBuilder1.Commit()
			theSession.DeleteUndoMark(markId3, Nothing)
			theSession.SetUndoMarkName(markId1, "Settings")
			editViewSettingsBuilder1.Destroy()
		'next
		'End If
	next
End Sub
End Module
Any tips how to repair it?
With best regards
Michael
RE: How to process all detailviews?
CODE
Option Strict Off
Imports System
Imports NXOpen
Module process_detail_views
    Sub Main(ByVal args() As String)
        For Each dview As NXOpen.Drawings.DraftingView In startSheet.SheetDraftingViews
            If Not TypeOf (dview) Is Drawings.DetailView Then
                'skip non detail views
                Continue For
            End If
            editViewSettingsBuilder1 = workPart.SettingsManager.CreateDrawingEditViewSettingsBuilder({dview})
        Next
    End Sub
End Module
www.nxjournaling.com
Thanks @Cowski. So the main problem was with calling view.
CODE
Why is {} so important?
With best regards
Michael
The curly braces tells the compiler to treat the variable as an array. It acts as a sort of shortcut to the following code:
CODE
dim myDetView(0) as DetailView
myDetView(0) = dView
editViewSettingsBuilder1 = workPart.SettingsManager.CreateDrawingEditViewSettingsBuilder(myDetView)
Thanks @Cowski, now it's all clear.
With best regards
Michael
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
