rQuestionEngineering
Would you consider SINOSEAL as a supplier for dry gas seal ?
It seem that the branded manufacturers are over rated and charging high prices.
Does the technology they had truly reflect the value and capability over others ? (apart that is it API qualified)
Essentially, these seal are just to keep the gas inside the compressor.
