Select cylindrical face with symbolic thread
niedzviedz
PL
Is there any way to select cylindrical faces but only the ones which has symbolic thread added?
With best regards
Michael
Do you want the code to automatically find and process these faces or are you looking for an interactive selection that limits the selection to faces with symbolic thread attached?
If you want the code to automatically find the faces, something like this may work.
If you want an interactive selection filtered for specific faces, it could be accomplished with the "SelectWithClassDialog" method.
www.nxjournaling.com
Thanks @Cowski, this is what I've been looking for. My old code was long and it wasn't process cylindrical face from unparametrised body, that's why I was looking for tweak it out.
below is my code, maybe it will be useful for someone.
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
	Dim theSession As Session = Session.GetSession()
	Dim theUfSession As UFSession = UFSession.GetUFSession()
	Dim workPart As Part = theSession.Parts.Work
	Dim lw As ListingWindow = theSession.ListingWindow
	Dim displayModification1 As DisplayModification
	Dim facecolor as integer = 160
	Sub Main()
		lw.Open()
		Dim threadFeatures As New List(Of Features.Feature)
		Dim threadFaces As New List(Of Face)
		For Each myFeature As Features.Feature In workPart.Features
			If myFeature.FeatureType.ToUpper = "SYMBOLIC_THREAD" Then
				threadFeatures.Add(myFeature)
			End If
		Next
		Dim myThreadParameters As UFModl.SymbThreadData
		For Each myFeature As Features.Feature In threadFeatures
			theUfSession.Modl.AskSymbThreadParms(myFeature.Tag, myThreadParameters)
			Dim threadedFace As Face
			threadedFace = Utilities.NXObjectManager.Get(myThreadParameters.cyl_face)
			threadFaces.Add(threadedFace)
		Next
		displayModification1 = theSession.DisplayManager.NewDisplayModification()
		With displayModification1
			.ApplyToAllFaces = False
			.NewColor = facecolor
			.Apply(threadFaces.toarray)
			.Dispose()
		End With
		lw.Close()
	End Sub
End Module
With best regards
Michael
