Contact US
Gas Turbine-Compressor
I want to know when we open recycle valves of the coupled compressor, the load of gas turbine increase or decrease?
Thank you.
RE: Gas Turbine-Compressor
You are unloading.
Depends what happens when you open the recycle valves.
Normally you have recycle when your flow drops below a critical level of surge.
SO the power should just freeze at that point as the compressor id doing the same work (same flow at the same differential pressure), only some of the gas is going back to where it starts.
so it neither increases or decreases.
Is that what you mean?
Either way, you will have less load with recycle open as opposed to when closed.
Why?
It's still doing the same flow with the same differential pressure just some of the gas is going round and round through the compressor, assuming the outlet pressure stays the same and some flow is leaving the compressor skid.
In practice your inlet pressure may go up a bit, but if you're opening the recycle because you've hit the surge limit.
But we don't know what the OP is really talking about...
Cause some gas is just going round and round, the compressor is not loaded as much as it would be if the gas was going through it. You don't open recycles when you're loading up, right. And, if you are talking about recycling for surge control, then the compressor is in the process of unloading itself anyway. "A number of conditions can lead to this (surge) phenomenon, but it primarily occurs under conditions in which the compressor is overloaded beyond its ability to move more gas. Essentially, the back pressure of the compressed air that is expelled from the compressor exceeds the compressor's maximum capacity." ... and flow reverses.
No work done , less power is used.
Look at the operating point on the compressor map. That will tell you how much work is being done.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
