Cylinder head failure
What are the dark areas on the fracture surface of an aluminum die casting?
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Cylinder head failure
Politicians like to panic, they need activity. It is their substitute for achievement.
Area of interest is upper left portion below as cast surface. Also, to the left of the tear on the right side.
TTFN (ta ta for now)
Apologize for the poor photo of this small piece. I've seen this failure before on a non engine application. It was a structural member that failed exhibiting the dark areas on the fracture surface. It was due to a casting defect from the producer but can't remember what was wrong in the casting process. The producer eventually fixed the problem.
Cheers
Greg Locock
