Assembly Save As
dakeb
81
I am new to Solid Edge and come from Catia/Creo. This is SE 2020 running on Teamcenter.
I want to do a save as using an existing assembly model, and at the same time save some of the components to new names, but not all.
I cannot seem to find the save as command that would list all the parts in the assembly so I can choose which ones to save as new.
Please could someone point me in the right direction?
Dave
Hi Dave,
I don't run Teamcenter, but I use Design Manager in Solid Edge. It will list all of the files in an assembly. From there, you can rename, move or copy files.
I'm not sure if this is the correct workflow for managed files systems. Also, try posting on the Solid Edge forum.
There are several users who are running Teamcenter and can provide more assistance.
Kyle
SE2021
Thanks I will ask there
