Pipe pressure class
nondimensional
I have a PCCP pipeline profile drawing showing pipeline pressure class as 100-6, 150-10, etc. I understand the first number is a pressure class. As in 100-6 means 100 psi pipe. But what does the second number mean - 6?
No idea about it.
Can you share the highlights of the drawing for it?
Might be amount of reinforcement.
Check if it relates to diameter, wall thickness etc.
GDD
Canada
This might be a project specific numbering system.
I didn't think concrete pipe went up that high in pressure.
Could be the indication of PN value, e.g. PN6, PN10?
I figured out that this was depth of cover. Thanks for all the input. Appreciate your responses.
PS: That was project specific numbering system.
