Contact US
VS4 pump for gasoline
I have a question about the type of bushing material that should be used in VS pumps, e.g. VS4. API 610 recommends the material filled carbon for bowl shaft bushings. What about pumping gasoline, i.e. flammable liquid. What about wetting the bushings, is it enough to wet the pumped liquid and avoid the risk of explosion.
Does the API 610 standard allow the use of bushing materials other than filled carbon?
RE: VS4 pump for gasoline
Some kind of helpful not.
Is it possible to wet the bushing with pumped liquid when pumping gasoline?
Try the pump forum.
What you suggest doesn't sound like a good idea so may not be suitable for gasoline service.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
