modal analysis, filter bracket
I'm trying to understand modal analysis. In my example I have a fuel filter bracket (flat plate, four holes to bolt on the engine and four holes for fuel filter). I won't to know what are the natural frequencies. Should I attach the filter to the bracket to get the real values? But what about hoses connected to the filter? I'm using Creo Simulate, but in the documentation there's a information that modal analysis can be only constrained or unconstrained but without loads. I need the analysis to know if the bracket will break under some engine RPM.
RE: modal analysis, filter bracket
Yes you will need to mount the bracket to the underlying structure for the frequencies to be meaningful.
Cheers
Greg Locock
I'll add some things
I would think so.
(2B)+(2B)' ?
