Contact US
Large Range Cooling Towers
I'm a junior engineer working on the design of a compressed air system that will use closed loop cooling towers to cool the compressors and dryers. In my office, the typical range we specify will be 10°F (95°F/85°F) and I'm not sure if we've ever not specified this. After talking to cooling tower vendors, I am looking at using towers with a 30°F range (115°F/85°F) with the benefits of less flow and possibly less costly towers.
Can anyone speak to their experience using larger range towers, particularly negative ones? The cons of this system I'm aware of are potentially slower response to compressor heat load and increased make-up water to the towers.
Any advice is appreciated, thanks.
RE: Large Range Cooling Towers
In the HVAC industry probably the largest market for cooing towers the current trend is to select cooling towers based on a range of 8 – 10°C.The tower return temperature is limited by chiller plant efficient operation which is at around 35-37C.This limitation is not so restrictive when selecting cooling towers for compressors or generators and therefore you can select a wider range for these equipment. What you need to do is to consult the vendor and understand from them the optimum water leaving temperature for the equipment and arrive at an appropriate range based on that temperature.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
