Contact US
ADAMS Request output steps
I 've tried a lot of different formulations and settings when trying to output a request file from and ADAMS model, but none of them managed to keep a completely steady output step. What I mean is that even thought I request an output about every 9e-5 seconds (10240 Hz sampling frequency), at some steps, the output time in the request file is larger, about 1e-4 seconds. Is there a way to guarantee an exact output step?
Thanks in advance!
RE: ADAMS Request output steps
Yes I did try using the FIXIT formulation for the integrator, even using a larger HRATIO so that the integration runs smoother, but still, when the request file is ouput the time values vary a lot.
The only other solution that comes to mind is to use an output step even smaller than the one I actaually need, so that the results are more accurate, but this whould require extra computations time.
Your idea of interpolating the time series in matlab is really good, but since the problem is not linear, won't the interpolation might result in false results?
Thanks in advance,
JK
I found a solution which didn't require decreasing the time step, one that fits my problem right now anyways.
I compared the ADAMS FFT plot results with the ones I compute using matlab and calculated a correction factor. This actually got the results pretty close and is quite consistent as a method so far.
Regardless, thanks for your advice. You 've been helpful in every question I posted here so far!
JK
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
