How to remove about 6K lbs of propane in Tank
Vivaldi SMITH
Student
I have an assignment that I quiet struglling with. We have a propane Tank that after inventory will hold around 6K lbs of propane. I have to come up with plans to remove that propane in order to let maintenance perform work inside the tank.
What can I use to remove , by flaring this remaining propane?
Cal your local propane distributor. They probably have a truck that is capable of pumping out a tank.
If not, phone around to their competitors. You will find one somewhere.
Ohm's law
Not just a good idea;
It's the LAW!
Agreed! Don't flare that sell it or give it away.
Hopefully you have a very VERY competent guide on how to do repairs inside a USED propane tank. That has deadly written all over it.
Keith Cress
kcress -
It would seem that having to ask such a question, the competence of making repairs to a propane tank is completely zero, unless of course the supposed poster is a "student" and his superior has set this as a learning exercise.
