Finite element mesh in DIANA FEA
Hello friends.
I'm using Diana FEA software to simulate a set of flat slabs, at first I was having good results, but looking at the image below it's possible to see a distortion in the mesh I adopted. I would like to know if any forum member has any solution to make this mesh more optimized, since I would like to leave it refined only in the region close to the pillar, even to reduce the computational cost.
*In the image the slab panel is rectangular with 1.5m side and the finite elements are solid type with 20 nodes, specifically CHX60.
Grateful for the attention.
RE: Finite element mesh in DIANA FEA
