Hello guys,
I'm working on DIANA FEA Version 10.7 for modelling of composite bridge. I was using version 10.2 before it was recently updated to the latest version. My problem now start with this latest version. Currently, I could not use compose line element to calculate the cross-section forces and moment in this latest version. The photo shown in the attached is the error message am receiving while running the analysis. Each time, after running the analysis to some point, it will just terminated. I don't really know what is the causing it. But I notice that when I removed the compose line element, the error message will not occur and the analysis will run perfectly. Please, what could be the likely problem and how to solve this issue? Thank you very much for your anticipated reply.
