I'm looking at a connection design for what I would call is a faux- mortise and tenon knee brace connection. The knee brace will be subject tension and compression (small loads). I'm mostly focusing on the tension brace for now.
I have attached two possible screw orientations and I have a few questions:
1. What brace seems intuitively "stronger" or which would you prefer?
2. How would you calculate the connection capacity? In KB1 the capacity of the screw in the "main member" is fairly straight forward. However, figuring out how to calculate the capacity of the side member seems fairly complex. The situation is reversed in KB2. But even in KB2 the end distance and thickness of the side member become complex questions.
Kicker Brace Joint Detail
I will share some additional thoughts and clarify my questions in a follow up post.
Thanks!
Thanks!
