How to suppress the CASE CONTROL ECHO in the .f06 output file?
I would like to suppress the echo of the CASE CONTROL SECTION in the .f06 file, equivalent to suppress the BULK DATA SECTION by using the Case Control Command ECHO=NONE.
Is there any way to do it? Any PARAM or config to set up?
Thank you!
Thank you!
RE: How to suppress the CASE CONTROL ECHO in the .f06 output file?
DG
