Cost of Precast Concrete (High Performance, Fly ash Included) vs Cast on Site
I'm having a hard time quantifying cost of precast (High f'c, fly ash in mix) vs Cast In place. I have done a lot of research but can't seem to find a decent answer.
RE: Cost of Precast Concrete (High Performance, Fly ash Included) vs Cast on Site
What item do you want to compare?
That can make a huge difference in cost. For example, a precast bridge slab is "cheap" compared to a similar cast-in-place bridge slab (which requires site-based elevated formwork & extensive field labor).
www.SlideRuleEra.net
If precast cannot be found, cast-in-place has the cost advantage.
