Post Tension Bridge Investigation
Musheir El-Farra
GB
Hello:
I wonder if anyone can advise me: I did few PTSI's 20 years ago. From memory; I used to allow for the intrusion of tendons at three locations along a profile of the ducting. Two at each side and one in the lowest point at mid span. Are the two on each side important/needed since they are in the area where shear is at a maximum ? This is other than intrusion into the anchorages.
This is of course within the limits which are recommended by CS 465
 https://files.engineering.com/getfile.aspx?folder=60aca33c-7c49-41c2-8503-aff56cf10513&file=PTSI.docx
