Air Compressor for Insitu Combustion Process in Oil Field
Dhiresh Bhimani
Petroleum
IN
I need a air compressor system for the above application.
Compressed Air requirement is about 1 million SCMD at 125 barg. Air is to be drawn from atmosphere at a max temperature of 45 deg C. Site is located in a tropical region.
Can someone please suggest the ideal type/configuration of the compressor system for the above application. Please also suggest possible vendors/OEMs.
Thanking you in advance..
Are you sure that it is a pressure of 125 barg (1813 psig) that you need ?
What is the quality of the air that you require ?..... Instrument Air quality ?
MJCronin
Sr. Process Engineer
Thanks for your interest.
Required pressure ( 125 barg ) is correct. This is not a instrument air application.
Compressed Air is required for in situ combustion.
Unless the batteries in my calculator need changing out , your compressor will require something like 20,000 HP. That would be an impressive facility. I suspect you need to refine your initial engineering
Have you investigated SAGD techniques? I haven't heard Insitu Combustion even discussed in the Canadian Insitu field for many years.
SAGD is everywhere, with suggestions of Steam being replaced by solvent.
Cenovus Energy, Insitu Recovery methods.
Bill
Ohm's law
Not just a good idea;
It's the LAW!
