The right solution for cutting Nitinol (super hard metal)/ Hard Steel core(bar)
Looking for a solution for cutting (super hard) Nitinol tubes and hard Steel cores(about 0.25" to 1"). Can "cold cutting saw" potentially be a solution? Im specifically asking about this method since I could avoid considering an exhaust system.
I would appreciate if you can share your comment with me.
RE: The right solution for cutting Nitinol (super hard metal)/ Hard Steel core(bar)
It may require a carbide tipped blade, and great care.
https://everettindustries.com/everett/wet-abrasive...
Carbide on hard materials would require very precise feed control and rigid fixturing.
Nitinol => nickel- titanium alloy [tube] material [that is bio-compatible]??
… AND also [separate-subject/material]...
UHS alloy steel [like bars, plate, etc]???
Regards, Wil Taylor
o Trust - But Verify!
Each material (and with tubing each wall thickness) will have its own blade/speed combination.
Cold saws are not fast, they are clean and precise. And expensive even before you start buying blades.
A good auto feed wet abrasive saw is a real option. They come with full hoods and take minimal ventilation.
Don't expect to get good cuts on difficult materials with a cheap solution, it doesn't work that way.
I would appreciate if you can give me a tip or any suggestion for the equipment.
The answers I found were literally mind bending...
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Of course wire EDM may also be an option.
TTFN (ta ta for now)
