Contact US
ELECTRIC SERVICE AMPACITY OF A MULTI-DWELLING BUILDING
Hi Gurus,
How do you determine if a building has sufficient ampacity for new installations without getting the landlord involved? I am profoundly interested in his leasehold, but the landlord has no idea if his property has sufficient power, but need me to figure out without getting him involved in any way. Building has 600A main disconnect switch servicing some tenants. I wanted to use data logging to asses the building peak load, but landlord wont allow. I would appreciate your suggestions. Thanks
RE: ELECTRIC SERVICE AMPACITY OF A MULTI-DWELLING BUILDING
If you're subject the NEC, you're probably out of luck then. There's a couple of paths, but both require cooperation of the building owner. The first is a utility bill analysis, the second is data logging. Otherwise you're probably stuck treating it all as new and figuring out the loading as it would be for a complete new design. That's going to overstate the load and leave you with less headroom than either of the other options.
I’ll see your silver lining and raise you two black clouds. - Protection Operations
Do some research on the revenue meter. You may find that the meter stores demand data even if the occupancy is not on a demand tariff.
Further to Davids excellent information;
Utility bill analysis is by far the quickest and cheapest for a service on a demand tariff.
With one or two years of back bills you may quickly determine accurate information that would take one or two years to accumulate with data logging.
\There is not enough information given for specific recommendations.
Bill
Ohm's law
Not just a good idea;
It's the LAW!
Of course, its likely an indication of the experience in dealing with the landlord if they're that helpful now.
EDMS Australia
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
