Restrict the range of travel for a component
Blase_McK
Industrial
I have an assembly that when I grab one part, the attached parts follow but the parts that are attached have a "set" range of travel. Inside NX (12) you can just pull the parts past the "max" range of travel with the move component tool.
Is there anyway to set up a boundary so that the parts will stay constrained inside that "min" "max" travel range, but still allow the parts to move freely inside that range using the move component tool?
I have attached a short Clip depicting what I'm talking about.
Blase
Sounds like a good use of distance and/or angle limit mates.
